Modern slot machines are no longer standalone devices. Gaming operators need remote monitoring, diagnostics, software updates, and operational management for machines deployed across casinos, entertainment venues, and other gaming locations - and they need them in real time.
At the same time, the requirements on security are strict. Unauthorized access to a machine could compromise both operational data and regulatory compliance. Relying on the local network of each venue is therefore not always possible or desirable, as a suitable network infrastructure may not be available at every location.
A gaming operator managing hundreds of slot machines across multiple locations needed a way to connect every machine to its central management system securely, independently of the venue's own network, and without the need for on-site intervention.
The key requirements were:
Each slot machine is equipped with an Advantech ICR-1642 industrial LTE router installed inside the cabinet. Thanks to its compact form factor, no additional networking equipment is required - the router connects the machine directly to the operator's infrastructure over the cellular network.
The router provides:
All routers are managed centrally through WebAccess/DMP, which provides real-time monitoring and parameter adjustment for the whole fleet from the remote operations center.
The routers are deployed machine by machine across the operator's locations. The rollout consists of the following steps:
If connectivity problems occur, the router automatically switches to the secondary SIM card to maintain uninterrupted communication.
By equipping slot machines with ICR-1642 routers and managing them through WebAccess/DMP, the gaming operator gained a secure and reliable communication channel to every machine, regardless of the local network at the venue.
The operator now benefits from:
