In the gas distribution industry, continuous real-time monitoring and control of infrastructure is essential for both safety and regulatory compliance. This includes gas pressure regulation stations and gas transfer nodes, which must remain online even in the event of equipment failure or communication disruptions.
A major gas utility company required a high-availability solution for its field stations across the country. Their primary challenge: how to ensure uninterrupted communication with PLCs and dataloggers at each site — even in the event of hardware failure — while adhering to strict security standards and working over legacy industrial protocols like Modbus RTU.
The key requirements were:
In addition, the system needed to be robust enough for harsh environments and easy to scale as the gas network expands.
Each gas transfer station was equipped with two Advantech ICR-2834 industrial LTE routers. These routers offer:
The routers were deployed in a fully redundant, cross-linked topology:
This architecture guarantees failover protection without needing additional switches or control units.
Entire network is managed through On-Premise WebAccess/DMP operating in safe company environment.
The implementation was executed in phases:
This design ensures that if one router fails or loses connectivity, the second router maintains full communication with all connected devices — delivering true high availability at the field level.
By implementing a redundant and secure communications infrastructure using Advantech ICR-2834 routers and WebAccess/DMP, the gas utility company achieved:
The project highlights how industrial IoT technology can modernize traditional infrastructure with zero compromise on safety, security, or uptime — critical factors for the energy sector.
