The industrial generator sector is rapidly evolving. Operators are moving from isolated, manually serviced units toward globally distributed fleets requiring unified digital oversight and reliable remote access.
Diesel and gas generator operators face recurring challenges: unpredictable failures, limited on-site diagnostics, high maintenance costs, and inconsistent connectivity in remote regions. Predictive maintenance — including integration of external vibration monitoring modules for detecting bearing and rotor issues — is increasingly important for preventing mechanical failures before they escalate.
To support this shift, fleet owners require a globally deployable industrial router that supports wide LTE band coverage, provides secure and stable connectivity, withstands harsh environmental conditions, and enables centralized, scalable fleet management.
The customer needed a compact global industrial router with remote access solution that could provide:
The solution needed to scale efficiently from tens to hundreds of generators worldwide.
The Advantech ICR-2545 delivered the required functionality, offering a globally compatible LTE router with robust industrial features:
Inside each generator, the ICR-2545 served as the primary communication gateway, linking internal control systems, customer-specific PLCs and any external diagnostic modules to the supervisory environment.
A key component of the deployment was WebAccess/DMP, used for:
Initial deployments in Europe and North America demonstrated the stability of the router’s global LTE connectivity under varying operator coverage. Dual SIM failover minimized downtime and ensured continuous remote access.
Through WebAccess/DMP, the customer unified connectivity monitoring, configuration management, and diagnostic access.
Using WebAccess/DMPs WireGuard, technicians accessed generator controllers and connected vibration-monitoring modules securely from anywhere, significantly reducing the number of on-site interventions.
After proving the stability of global LTE operation and the efficiency of centralized WebAccess/DMP management platform, the solution was deployed across hundreds of generator units in Asia, Europe, and North America.
.png)
With the Advantech ICR-2545 and WebAccess/DMP, the customer unified connectivity and remote management across a global fleet of industrial power generators. The combination of global LTE support, rugged hardware, strong security features, and centralized fleet management through WebAccess/DMP provided a resilient communication backbone that:
