Energy companies and industrial operators often face the challenge of reliably connecting substations and remote assets to their SCADA control rooms. Traditional serial line connections using the IEC 60870-5-101 protocol can be costly, limited in capacity, and complex to manage. With the growing demand for secure, scalable, and cost-efficient networking, there is a need for industrial-grade wireless gateways that support modern IP-based communication without compromising compatibility with existing IEC standards.
The Advantech ICR-2400 series of industrial cellular routers addresses this need. Designed for critical energy infrastructure and industrial IoT, the routers combine LTE connectivity (including specialized 450 MHz bands for deep coverage in remote areas), robust interfaces (Ethernet, serial, digital I/O), and an open Linux-based OS for integration and customization.
To modernize their SCADA infrastructure, energy operators needed a communication solution that could bridge legacy serial systems with IP-based networks while ensuring reliability, security, and cost efficiency. The system therefore had to meet several critical requirements:
The ICR-2400 IEC101/104 gateways enable transparent conversion between IEC 60870-5-101 and IEC 60870-5-104 communication standards. Using a dedicated Router App, the solution translates IEC101 serial communication into IEC104 TCP/IP communication and vice versa. This allows substations to remain compatible with legacy devices while benefiting from the scalability and cost-efficiency of Ethernet/IP networks.
Key features include:
By supporting both high-bandwidth LTE Cat. 4 and low-power LTE Cat-M/NB modes, the ICR-2400 series can be tailored for applications requiring either performance or efficiency.
In a typical deployment, substations equipped with RTUs running IEC 60870-5-101 are connected to control centers operating on IEC 60870-5-104. The ICR-2400 gateway acts as a seamless bridge, reducing the need for leased serial lines and enabling communication over modern IP networks.
System integrators configure the IEC parameters via the router’s web interface, assign independent conversions for each serial port if required, and enable VPN-based security. Once deployed, the gateways provide 24/7 remote monitoring, diagnostics, and secure data transfer, while minimizing on-site service requirements thanks to wireless redundancy.
